So just to verify 5 3/8" post war headtube is 136.5 mm and if you use the Neco alloy headset that Porkchop sells, and I have a few times, that is 41 mm leaving you with 177.5 mm and the Tange fork is 180 mm, so it will fit with a small cut or a small spacer or it will "just button up." The Tange MX 320 headset is 40mm height. I dont know what the Schwinn headset stack height is, but it is great quality and you can get a nice clean one quite easily. Your prewar is 5" headtube so that is even more in the clear. Does my math line up?
