Windsor Profesional information?
Given the "portactena" rear drop-out I would date it at no earlier than 1977, but most likely '78 to mid 80s. I am not familiar specifically with the bike's livery or changes, if any, through the years; or of a Pro's features compared to other models they produced. If the PAT. 84 RD is original to it than it certainly would fit as being circa '84/'85; I doubt those drop-outs were used much later than that unless old stock parts.
OK, thanks. That'll help me for the introspective as we develop the exhibit and for locating it in a catalog. Wouldn't have thought it was so late...
@whistlestop that particular Campagnolo drop-out was introduced in their 1978 catalog supplement. It may have been available to some builders in 1977. Seeing that all the cable guides are braze-ons, and having the bottle cage mounting also tends to put it in the later 70s to early/mid '80s. The front derailleur style was not introduced until around 1980. A 4 hole cage version was available in '78 and was found in the same catalog as the drop-outs, but was discontinued about a year to 2 years later due to design issues. If the rear derailleur is original then that would be your best gauge as to the manufacturing date.
if you determine cycle's hubs to be original the date marking on the inner face of the axle lock nuts should be of help
OKgreat. I'm not a Campy fan so this'll help as I move forward.
I have wondered about the lugs used on this Acermex import? Bought this Carabela because of the beautiful head lug.
lug pattern an Agrati one
do not have name or number for it
on cycling fora it is sometimes identified as a Bozzi pattern as it appears in the Bozzi catalogue of 1950 which has been posted online
Bozzi a reseller rather than a fabricator of fittings
situation similar to the Umberto Dei & Doniselli catalogues
the seat lug in this illustration is Malaguti style
Agrati offered seat lugs in three choices:
a) bare, without binder ears or Malaguti plugs
b) with binder ears and without Malaguti plugs
c) with Malaguti plugs and without binder ears
Acer-Mex emplyed the b) option
the fork crown on your Carabela is Agrati pattern "BRIANZA" and is item N. 000.8038
this crown was also offered in a version without cutouts which was used widely by Torresini (Torpado)
here is a lug assortment illustration from the Bozzi catalogue of 1950
Bozzi lugs:crowns .jpg
pattern shown in upper left is "BRIANZA"
those shown in upper right are "AM"
your Carabela appears to be the model parallel to the Windsor Carrera Sport of the early 1970's
the frame of the cycle exhibits the odd combination of an Italian threaded shell which is 68mm in width and a BSC threaded steerer & headset with an .833 inside diameter & stem
the MAEDA housing stop is a helpful dating clue;
by about 1974 this was revised so that the stops are sockets rather than simple flats which often got bent
existance of the Carabela product range was a means for the factory to pack more product into a given market
after a distributor's salespeople had gone through their territory and signed up as many Windsor stockists as they could they then would recover the same territory signing up Carabela stockists from amongst those retailers who had not opted for Windsor
