Wingbar Detail
TR6SC
1,050
2,798
67
Eureka, CA
#1
I need help. Will someone out there post a photo of what this area should look like. The downtube is loose in the casting. I'm thinking of welding the pieces together. Is a steel sleeve involved? And, what is the hole in the side for? I've drilled out the post and would like to head in the right direction. Thanks.
TINYuproar
Oct 19, 2013
215
98
Grand Rapids, MI, United States
#2
View attachment 676242 I need help. Will someone out there post a photo of what this area should look like. The downtube is loose in the casting. I'm thinking of welding the pieces together. Is a steel sleeve involved? And, what is the hole in the side for? I've drilled out the post and would like to head in the right direction. Thanks. View attachment 676241
I heard from someone in my thread on my round-tube '36 SK that a cotter-pin type item goes in that hole. It was originally steel...which seems to always be the problem with the SKs when a dash of time is added.
Also, here's another article with a fairly detailed repair involving drilling that cotter pin.
http://www.coroflot.com/feralinnovations/Monark-Tube-Repair
Not a fan of the repair detail on that SK. BUT to each their own.
...and here's mine...rusted to sh*t.
Hope that helps!
