Thanks @AS-1 for adding these photos to this thread for me. The three parts are Salesmen's samples that were handed out at a sales meeting when Schwinn introduced the new frame building that would be done at the "then new" Greenville, MS factory. They show the way that that the new single piece head tube was investment cast. The lugs are crisp and clean, no clean up or fitting was required as this was a precision cast part. Just insert the "prepared frame tube", heat it up to melt the brazing slug, and it was ready for paint.
The bottom bracket is interesting in that it has two steel threaded sleeves inserted "after" the case part was made. The sleeves have four large spot welds (two on each side) securing them to the cast part. The casting is the same as the head tube.
The seat lug is also investment cast. But it has a steel "crush tube" added inside the area where the seat post clamp bolt would be placed. The steel stiffener (crush tube) is TIG welded to the cast lug to hold the very small part in place during the frame building and heating process. After the frame welding was completed, "All of the TIG Welding" was cut away when they slotted the back of the seat tube to allow the clamp bolt to tighten the seat post.
These are visual samples of what I call the Uni-Lug design that was used on every "steel framed" bike built in Greenville. This was to be the next generation of Schwinn's "after Electro Forged" production ended.
John
(added per request from John)
