Hi,
I have pulled the hub apart and I am inspecting each of the components on a Morrow/Eclipse 36 10 date code M3 rear hub. The brake sleeve is worn however looks to have never been grooved which maybe was the case with early ones?. The steel case that the brass is riveted to is cracked through and I think will have to be replaced. I don't think a weld repair will work given the way they work with expansion/contraction. Does anyone know a source for these?.
Thanks in advance,
Brett.
Thanks in advance,
Brett.
