I took the pedals off today they are both right hand threads? I have never seen that before. Thanks, Kirk
Yes, I have seen right hand pedal threads on both sides on some early bicycles, before manufacturers figured out that the pedal on the left side would loosen while riding which is the reason for left hand pedal threads on the left side. I believe two right hand threaded pedals was a carryover from highwheels and hard tire safeties which had pedals that typically were both right hand thread however had only a hole through the crank arm and a nut on the back side of the crank arm to attach the pedal.
Reason pedals are opposite threaded today.
Quote from:
https://physics.stackexchange.com/ "Intuitively you would think pedals would unscrew while pedaling! But in reality the clamping torque of the threads will be far, far greater than any friction in the bearings could generate. Even if the bearings were to seize, it would be very difficult to unscrew the pedal (unless it was never tight to begin with).
Now consider someone riding the bike, putting weight on the right pedal. This applies a force perpendicular to the ground, no matter where the foot is in the pedal stroke. Relative to the crank arm, this radial force rotates CCW, which - via the process of mechanical precession - creates a CW torque on the pedal spindle (thus tightening it). The rotations on the left side are all reversed, so it must use the opposite threading to prevent the pedal from coming loose."
The fact that your Remington has both right hand threaded pedals is another good reason for believing it is 1896 model year rather than later when left hand thread pedals on left side were implemented. Possibly your Remington may have even been produced in the last couple months of 1895 as the new 1896 model because it clearly does have the newer 1896 style crank and not the earlier 1895 style.
