Girlbike
Yes, the brakes weren't working as good. And it was making a little rattle noise when coasting sometimes. I don't think I used the right grease, but I have a tub of white lithium grease.If you look into the axle you should see a slotted screw head. That piece may be missing as well. If the axle is hollow then you have to determine if exactly what parts are in need of. The gear levers are specific to the manual it has a solid metal cable cover that needs to be securely mounted to the bike frame. bicyclebones did sell the part that mounts on the end of the axle and is activated by the cable which he also sold at one time. I do not think he sold the lever but they do come up for sale. It seems like cables in good condition and the clamps are the most often the hard part to find. Did you say you had the hub apart?
I figured the planetary gears were some sort of torque multiplier for the brakes. Looking back at all the evidence, of course it's some sort of geared hub.
I didn't see any screw inside the axle,or any means of control. I've got a couple other things to do today, but I will definitely get it apart again and replace the grease if nothing else pretty soon.
In the meantime, thank you very much for trying to school a relative noob.
