Bumblebee 99% complete
Why is it needed? Didn't have one in mine....ran wonderful. ??? Does it give more torque? Know smaller venturi carbs give better torque and less top end.
I'll have to look when I get home. I really can't remember.......all I know is it ran perfect on the bench.
PS.... don't put on decals, looks great the way she is. I have some tho if you need them.
I have them........and I think I'll hold them up to the tank and see. Right now I like the clean look.
yea, you don't need to advertise.... the original Whizzer Co. is out of business. Anyone that would appreciate it already knows what it is anywho..... :)
You guys would be wise to listen to Ray when he tells you something about a whizzer. What do you think,whizzer decided to pipe that down for giggles?
I can't remember if it has one or not.......all I remember is it ran like a raped ape on the bench. Idled like a dream and was rebuilt by a guy who has done more Whizzer engines than anyone I know. I'm sure Ray knows Whizzers. If it ain't broke.......don't fix it. I'll look tonight and solve the intake mystery.
Don
Don
I believe they did away with them when the J came out. But J used the Model N carb too..... Think 300's had a different carb also. J had a bit bigger valving too if I remember correctly. and a shorter intake tunnel.
The H intake port is larger than the carb 7/16 .The tube gives it the proper size,don't wanna run your motor lean.Keep an eye on your plug. you do want a good fuel charge right?
Let me see your carb when you get a chance, see if the bushing looks worn,never get it to idle,or maybe a worn shaft.
Ray
