The forks are smooth, much like a Schwinn.
They don't look cut, if they were, its been a long time and a lot of use since, and the steer tube matches the color inside the BB shell.
There's some old headset parts in the box on which the top cone is very thin, and the lock ring has only a key tab on it, when assembled, the bearing, cone, and lock keyed plate are all below the level of the cup. With the Wald, the cone is thick, and incorporates a thumb ring, then a keyed washer, then the nut. Only about 1/3 of the nut engages the threads. The crown race is also not original, its thinner than the original by half but they got spacers under it so the cup doesn't drag the fork crown I suppose. If the crown race was any lower the cup would hit the fender tab. Its pretty close even with the shims.
I think the bottom line is that I need to find some original parts, the modern Wald stuff just don't work on this.
I don't want to turn it into a full restoration though, its certainly not that kind of bike, but I will make it ride able again with as many original parts as I can find in my junk drawers here.
Was Western Flyer the only badge to go on this type of frame?
