DeDion
juvela
1,263
Playa del Rey, United States
Thanks very much for sharing this! ;)
They became famous for their suspension systems for sports cars.
Were you able to identify the bare metal frame in the second image?
Appears lugless but cannot quite be sure...
Example believed to date from ~1939 -
Factory from 1924 -
Some company history here -
https://en.wikipedia.org/wiki/De_Dion-Bouton
FSH
Aug 27, 2018
274
Corona
Factory from 1924 -
Yes, that is the DeDion side view
bulldog1935
3,821
Bulverde, TX
of course, DeDion is famous for their triangular rear suspension design, 1905, originally to make a roll-proof tricycle, but the design found its way into a few sticky automobiles, as well.
Reactions: dnc1 and FSH
bulldog1935
3,821
Bulverde, TX
That's quite a thumper.
Through the 50s, DeDion was the only rear suspension used in Formula 1.
Even though the suspension was designed by Bouton, DeDion has always received the credit for the patents.
Reactions: FSH
1motime
Aug 7, 2019
389
65
El Segundo, CA
Shakes like an earthquake when idling. This single will smooth out and rev to around 1600 rpm! Light weight and it flies. More of an issue to hang on and hope the brakes are dry and willing! Rear brakes are for emergency. It has a driveshaft brake that does most of the work.
bulldog1935
3,821
Bulverde, TX
btw, it wasn't that DeDion ever produced sports car suspensions, considered them, or even used the suspension design in their own automobiles
Bouton designed it to make a tricycle roll-proof.
The dead axle rear suspension produced such high roll center (SAE racing barstools) for such low unsprung weight, once the patents expired, it was adopted by every automobile employing a prop shaft and rear transaxle and pushing the envelope, up until Cooper Climax demonstrated that with good geometry, independent double-A-arm rear suspension could get there with the edge of lower weight.
And still used on the Alfa Six, earlier and later variants.
dnc1
2,022
53
Wallingford, Oxfordshire, UK
De Dion Bouton are one of the few cycle manufacturers who produced cars before going into cycle production; rather than producing bicycles, then cars/motorcycles as many companies did.
It's all tied in with the 'Dreyfuss Affair' in France at the TOC, differring political and ideological points of view and social class rivalry.
Of everything I've read, the Count de Dion was a not very pleasant man.
Le Tour de France is the result of all the shenanigans that occurred though, so "every cloud....."!
Reactions: bulldog1935
bulldog1935
3,821
Bulverde, TX
Very good point. Harry M. Pope began with steel pipe/tube for boilers, water, sewer, expanded to his first love rifles and precision target sights,
before naturally moving into Pope bicycles and later, Columbia bicycles.
Reactions: dnc1
