I called ML to see if they had an idea.
Looks like I got it out of wack when I replaced the points cover.
The original owner had the condinsor wire routed outside the motor and attached to the points cover screw...BUT they didn't have it routed through the hole on the motor for that wire. They had drilled out a slot for it on the actual points cover they made for the wire.
So when I bought my points cover, I rerouted it the correct way.....(loosening the set screw in the process and throwing the points out of wack)
Duhhhhhhhh
So now i'm about to reset them correctly and see where I'm at.
Setting the IGN on flywheel to the TM on the block and adjusting the gap at 0.015...
