You can find drop stands. Their not cheap. ALSO , yes , different sizes and styles. Search for one that is specific to Westfield/Columbia . Others may work . You will also need the clip. All clips do not fit all stands....................so get the two together if you can. Measure your bike ahead of your search ( Hole behind the "Ears " at rear dropout ) to farthest point back on rear fender . this should get you in the ballpark for "length" Not sure if your should be braced or not. Maybe someone here has one you can see for the style , and measurements. Be patient you will find one.
Almost forgot.............What diameter lenze do you need....................I have some spares layin' around .
