Prewar Hawthorne Chain Tensioner Help
jlively970
Jan 24, 2019
129
39
basalt, colorado
Hello, I am looking for the correct diameter chain tensioners for my ladies prewar Hawthorne ballon tire bike - the ones that came with the bike were completely roached. I tried the NOS CWC chain tensioners in pics on the right and they are just slightly too big in diameter. You can see in the first caliper pic the OG measured 0.2115” and the NOS ones measure 0.2415”. I’m an unsure of the thread pitch also... Lastly, I’m not sure if the OG ones had nipples on the the end of the bolt or not... any help, knowledge, info, or parts would be greatly appreciated. It’d be good to get the lady back on the road!
Thanks in advance
Reactions: Balloonoob
piercer_99
1,929
59
Sanger, TX
the two fatter ones you have, with the nuts on them, are from a pre war Westfield built Elgin, or similar Westfield built machine.
The narrower dimension that came off of your Hawthorne, looks similar to post war Huffman, which had the nipple on them originally.
I had a similar problem trying to use CWC tension screws on a Huffman, they were just a bit wider and stripped out.
Good luck.
Archie Sturmer
1,059
Los Angeles, CA, USA
I believe that the 0.21875" equals 7/32" or about #12-24.
1/4" = .25" might be too big, and #10 = 0.1875" (e.g., Colson) might be too small.
Hope this helps.
Huffman also used a square nut, (with mating threads), inside the frame slot - I believe that the frame might not be threaded, and may act more like a guide, the square nut is the fastener opposing the forces on the axle. So a 1/4" might just force-fit in the frame, but a small enough nut that also fits may be hard to find.
New Mexico Brant
2,552
50
Santa Fe, New Mexico
www.BrantMackley.com
Hope this helps.
@Mercian
Reactions: piercer_99
jlively970
Jan 24, 2019
129
39
basalt, colorado
Good luck.
Great information and thanks a lot, now I know what I’m looking for!
jlively970
Jan 24, 2019
129
39
basalt, colorado
Hope this helps.
This is really great information, where did you find that data on the screw chain adjusters? Thank you
Archie Sturmer
1,059
jlively970
Jan 24, 2019
129
39
basalt, colorado
