I ended up using a 14mm to remove the rounded bolt and got to the root of the problem. I think it is the exhaust valve that was stuck, looks like the limit nut adjusted it's self over the years causing the valve to corrode. I promise to grab some cleaner pictures on the rebuild.
So I have everything cleaned and ready to put back together. Where is the best place to get complete gasket sets, correct threaded bolts and period correct used parts. I still need to find a few pieces but I think I have enough to get it started.
