Sturmey Archer 3-speed 36H hub, drilled for heavy duty 12 gauge (2.6mm) spokes
The only steel Sturmey hubs I have seen have been drilled up in a back shop, not factory drilled. I believe your only factory drilled options are later model aluminum hubs.
Using one of these is problematic though since they are wider...and that requires spreading/cold setting of the frame and realignment of the drop outs....plus that hub needs special controls that are different than vintage stuff and they arent included with it.
