Lambert identification
marius.suiram
1,553
Cleveland - Ohio
The bike has Lamber crank set, rear wheel is a Ukai with Lambert hub, bars.
Brooks professional saddle.
Gran Compe brakes.
Suntour Cyclone derailleurs and endbar shifters.
I didn't find any serial number, but on the frame there are a lot of stickers (what should I use to get rid of them?)
The fork is probably a replacement, but no signs of damage at the frame.
Any idea of the year of fabrication?
slowride
Nov 8, 2017
132
Detroit, MI, United States
Stickers- Heat gun on low setting and plastic scraper. Be careful to apply only on sticker and only briefly so as not to damage paint. Lighter fluid to remove residue.
bulldog1935
3,824
Bulverde, TX
their lugs are exact copies of Raleigh's
spoker
5,242
Minneapolis, United States
dont ride it with that fork, they snap off,company went out of bussiness with so many law suits
detroitbike
1,067
Detroit , Michigan
The fork on the bike is a replacement. I sold the bikes NEW in the '70's and later replaced
the forks for the recall. I Never saw a broken fork...
sam
1,476
San Antonio, United States
Those lambert cranks are not Sq taper just Square. and the spindal has keeper rings so it's grooved and that causes weak spots also the BB is not threaded.
Reactions: bulldog1935
dweenk
Nov 13, 2014
212
Maryland
From Sheldon Brown:
The "Death Fork"
The bikes (both Lamberts and Viscounts) came with a cast aluminium (aluminum) fork which was pinned to a steel steerertube. Early production didn't even have the pin. This fork was the main problem as it had a tendency to snap off the steerer tube with predictably unfortunate consequences to the rider.
UNDER NO CIRCUMSTANCES SHOULD A LAMBERT OR VISCOUNT BE RIDDEN WITH THE ORIGINAL CAST ALUMINUM FORK!!!!!!!!!
(Having said that, I ignorantly rode my Viscount with the original fork for 8 years including many 40-45 mph descents in the bluff country of southeastern Minnesota for 6 of those years. The patron saints were working overtime for me!).
Yamaha purchased the Viscount in 1978 or so and promptly recalled every cast aluminum fork ever sold on a Viscount or Lambert, replacing them with a chromed steel Tange fork."
Put a magnet on the fork blade - then you'll know what you have.
bulldog1935
3,824
Bulverde, TX
It's the dumbest design ever - taking the part of the bike that functions more as a shock absorber than any other part, and making it out of a material with no endurance limit and with inherent manufacturing flaws. With continued use, they are guaranteed to crack at some point in time. Even forged aluminum with fewer and smaller inherent flaws, would eventually crack in this application.
The beauty of steel is that it has an endurance limit - a stress value below which it is monolithic and will not crack.
I'm a metallurgist and licensed professional engineer. Stated simply, I know more about destroying things than anyone else you may know. About 10% of my work is product liability litigation - 90% doing the same thing for industry.
