best degreaser easy off oven cleaner original formula yellow can
i use an old metal pot.......dump chain in pot, spray liberally & let sit 2-3 minutes & use an old stiff paint brush to loosen any heavy grease, hose off with lots of water, hang chain on nail and hit with a heat gun to dry., then oil/wax/whatever you prefer.
I sometimes use wd 40 (water displacement) after cleaning if storing for later use, NOTE; WD 40 IS NOT. REPEAT NOT A GOOD CHAIN LUBE OR RUST BUSTER!!!!!!!!!!!!!!!!!!
Wear rubber gloves unless you're going for the parchment paper skin look
