Greetings sure could use some help with a Hawthorne early 1920's bicycle BB race cup sizing. Did Hawthorne use pre-war Schwinn cups? Mine has Schwinn crank, cones and bearings 10 x5/16 Would like to replace worn race cups. Any info much appreciated
I might have BB cups that mate to your bearings. Are bearings #66 or equivalent? If no stamping, what is retainer outer diameter?
There also another 10 ball 5/16" retainer that smaller outer diameter vs 66. Both have 10 ball 5/16 but different diameter so cups not interchangeable
If you have 66 bearings, hopefully your current crankarm / fixed and adjusting cones are corresponding for proper seating fit. Crankarm cones for 64 will not sit correctly on 66 bearings, vice versa.
Assuming your bearings and crankarm cones match, here are some measurements for 66 BB cups. Cups for 66 bearings are abundant.
For reference, here are 9 ball bearing retainer measurements, some schwinn crankarm/cones used 9 ball. The 9 ball BB cup has a small diameter at seating depth.
