Schwinn Decal Replacement
Advise Please: I need to put decals on an 81 Cruiser 5 that I am just cleaning up. Paint is super but decals or screening is very faint. I just want the bike to look good, it is not going to be a show quality restoration. I have never used vinyl only water transfers and I have had a few of them from ML come apart as soon as water hit them. Any suggestions? Thank you
MLC's and Bicyclebones should have what you need. I've seen the decals you need off and on from different sellers on eBay but they were probably decals they purchased and didn't use or old stock from closed bike shops and no longer being sold by those sellers. Dan's Schwinn feather script decals are most likely copies of the 1954-58 issue and the Cruiser's decal is somewhat the same but has been noted by a member here that there is a slight difference between the two issues. If there's a concern the decals will fail when dipped in water, do a decal pre-treat with a layer of clear lacquer.
1
Sorry I forgot where I got my decals.
The top bar decal by everybody else is wrong, I bought others which were sized wrong. And checked sizes with everybody I could find. Almost an actual inch to long until I ran across, the only person and site that's got it right.
I do not know whether other decals are wrong but, I recommend you contact : http://www.vintageschwinn.com/decals.html#
Right: 10-1/4"
Wrong 11-1/16"
Specifically, although not sure fire method but, watch for the dot, above the I in Schw 'i' nn. it should be level with the scowl line, not poking above it as can see in lower, too long 11-1/16" decal. .
Right: 10-1/4"
Wrong 11-1/16"
Thanks......If the ones I ordered are too long it will be easy to section each end to get the correct length.
Nope, it's tough enough to get the feather scowl line on, but this is a point everybody misses: Specifically, although not sure fire method but, watch for the dot, above the I in Schw 'i' nn. it should be level with the scowl line, not poking above it as can see within my photo, in lower, too long 11-1/16" decal. Not only will the thickness of the font be wrong because the others are stretched before printing but, you try and cut it down and rejoin em?,, yeah, good luck wit dat thought, [grin}
Vintage Schwinn is the only one who's got it right, in their photos and proved once I recived a set through them:
Some of the deluxe models, which are the only ones I've seen that are really thick and go this far but, illustrate how different the font thickness on them can be. That is, many original decals vary in font thickness. likely due to the rapid printing, and many of the Deluxe's show the degree in the change that all of the 80-82 Cruiser's can have. Hence, the replica's letter thickness is wrong because whoever printed them screwed em up from the get go. probably photographed them and inside of photoshop, miscalculated the width, which would be stretched.
The top of this photos is the crap "Authorized" ? LOL while bottom is on an real, original Cruiser Deluxe. I donno maybe they put the best on the deluxe while the 5's and standards can vary in thickness in the letters, fat too slightly thinner than. Yet they're not, fricken 11-1/16" Inches long like the so called "authorized" are! :
I seriously doubt I will have anyone checking it out that closely. This is the last ones I bought. Right or wrong ?
I seriously doubt I will have anyone checking it out that closely. This is the last ones I bought. Right or wrong ? View attachment 449307
That looks like a vinyl sticker, verses decal but, the print looks correct for the top bar.
But me tinks this may be what you were going for? This type, pretty sure is an actual Schwinn made version, but don't know what was on. It has a thinner feather scroll line verses any and the dot above the I is high centered plus is straight verses curved , [wink] I recall seeing this type some time ago, but ferget, maybe mid to late 70's . I happened across it though, and saved photo of it for future use, but more to be found on this link:
http://www.ebay.com/itm/SCHWINN-PHANTOM-PANTHER-HORNET-BICYCLE-TANK-/192111514813?_trksid=p2047675.l2557&ssPageName=STRK:MEBIDX:IT&nma=true&si=YSuRd6BEHb0oLFDhptSeJ0X1TG0%3D&orig_cvip=true&rt=nc
No horn and has a hole in tank for the cable:
What I was going for was the curved feather script so it followed the indentation of the tank. IMO it looks better than the straight line on the yellow tank.
