Interesting idea. I think I'd have to see it in action more before I'd buy something involved or expensive. I don't pull enough stuck seat posts to make something expensive worthwhile. I'm not a big fan of repeated hammering because it shakes everything loose on the bike, and I suppose could crack a seat mast joint on brazed frames.
The last one I pulled - cut off the seat post top, insert and tighten a quill stem inside the cut-off post, use a set of old handlebars in the stem as leverage to twist and pull the post out. No hammering needed. There was enough post above the frame that I didn't need to go down into the frame with the stem wedge. I believe the post was just plain stuck, not chemically welded into place (at least no signs of
The last one I pulled - cut off the seat post top, insert and tighten a quill stem inside the cut-off post, use a set of old handlebars in the stem as leverage to twist and pull the post out. No hammering needed. There was enough post above the frame that I didn't need to go down into the frame with the stem wedge. I believe the post was just plain stuck, not chemically welded into place (at least no signs of it).
Honorable Sir Mike, that is a great idea. I have a stuck seatpost on an old Murray that is jammed into the tube, with not enough stem to really get ahold of it to pull. Using a quill stem seems like it will be perfect. But the top of the post that is showing is sort of oval shaped, like it was squeezed. So it's stuck. But this should work...with some P Blaster, of course. Here are some pics. It's a Murray Westport...26 inch. Found next to a dumpster. Bearings are all good. I'm just going to clean and preserve it, with a vintage leather saddle and cream tires, for an old board track look.
