'59 White Corvette, A Gentle Restoration
Here is a red Schwinn Fairlady frame. Built on Feb 6, 1959. Would this be a suitable test subject?
Look at this on eBay http://www.ebay.com/itm/263442647322
EDIT: forgot the link!!
Nope. Not like the white Corvette and Fair Lady decals. Here's what I would do it that were mine, but I'm crazy. I'd carefully clean the decals and the paint directly around the decals and then put a piss coat of clear lacquer over them. Then soak the frame.
partsguy
I know the decals look different, but I am hoping the material might be the same?
It appears that the gold fades out and the red is fairly stable on these decals, so I'd assume they are not quite the same as the solid white decals.
island schwinn
Exactly,as mentioned before,I have a feeling the gold is actually screened over the red decal,making it as fragile as stingray guard screening..
partsguy
What about this ole girl I found on eBay? Seems to have the same seat tube decal? Similar top tube decal also?
http://rover.ebay.com/rover/1/711-5...0001&campid=5335809022&icep_item=263469673906
Rides4Fun
Partsguy, I’m really enjoying your threads! Learning a lot about taking time and using patience with regard to projects...whether it be a Radio Bike or the white ‘59 Corvette.
Thanks for posting your experiences,
Barry
partsguy
A Schwinn buddy of mine came over and gave me a tip for my gaurd. To fix the rust on the backside, soak some paper towels with Evaporust, and place them on the backside, with some on top. Check periodically. This will not harm the paint on the front. :sunglasses:
schwinnbikebobb
Funny you mention that. Just yesterday did a Evaporust Gel test on a chainguard. The gel was pretty thick so it stuck well. I used a foam brush to move it around. You only leave it on for a couple of hours. I did 2 applications on this. This one was bad on the back but pretty good paint so a good test. Not going to make it perfect but it looks a lot better to me. See what you think.
