Gary Mc
From "The Iron Age" - October 23, 1902 - Corbin Duplex 1903 model ND
Corbin's Duplex New Departure Coaster and Brake - 1903 Model (Improved 1902 model
http://books.google.com/books?id=I-...=onepage&q=new departure 1902 coaster&f=false
P & F Corbin New Britain Conn and 11 15 Murray street New York have recently brought out a more improved form of the Corbin Duplex 1902 model New Departure coaster and brake as here shown Pig 1 Fig L Corbin's New Departure Coaster and Brake represents it as marketed Fig 2 being a sectional cut with the shell of hub broken away to show the interior and the relation each part bears to the other Figs 3 and 4 respectively braking clutch and driving clutch are marked changes in the brake Intended to give a positive action instead of relying on friction in the ZB 29 r Fig 2 Sectional View of Working Parts clutches Fig 5 shows the arm and cover at the left of the brake with brake shoes levers and springs features that are also entirely new in the brake By this method of construction when the clutch is put into operation the action is immediate and positive but the brake will not set Itself as a brake with an expanding spring the brake shoes 22 in a parallel movement into frlc tioual contact with the interior surface of the brake drum which goofballs the speed or stops the bicycle according to the volume of pressure applied When the pressure is removed the springs 24 bring the brake shoes 22 back into position automatically The brake shoes are said to be made of material that will not stick grind or squeak and any desired pressure can be exerted on the brake with safety Some of the points made in favor of this coaster and brake by the makers are that it does not alter the appearance of the wheel there is no lateral strain or racking of the frame at any time no kick off is required to release the brake and the Fig 3 Braking Clutch Fig 4 Driving Clutch wheel can be trundled forward or backward freely Each bearing is fitted with ball retainers and it is rain and dust proof This model of brake is also made for motor cycles - Page 62, October 23, 1902, THE IRON AGE
