Has anyone changed front chain ring
phantom
1,306
GA
Anyone changed the OE chain ring on a 52 tooth Phantom to a 46 tooth Clover leaf type?
bricycle
Nov 18, 2009
23,017
Chicago area west
oh yea, but think the clovers are mostly 48's. Give you a bit more low-end power.
Reactions: phantom
phantom
1,306
GA
Thanks, I did mean 48......I like the look, I want more low end and there is room in the dropouts to pull the wheel back a tad. I don't want to change the rear cog as I am sure that will entail making adjustments to the chain.
bricycle
Nov 18, 2009
23,017
Chicago area west
there are other smaller sweetheart sprockets, not that Phantom's had them.
bikemonkey
1,323
67
Replacing either the chainring or rear cog will probably require a lengthening or shortening of the chain.
If you want a lower gear I am thinking that changing the chainring will mean removing a link and a half of chain (or more) and be a much more labor intensive solution. If you have ever fought a fixed bearing cone on a Schwinn crank then you know what I mean...
I just changed the 18T r. cog on a Deluxe cruiser to a 20T for a customer and they liked the improvement in the easier pedaling. I needed to add a link and a half of chain - time in the repair stand was about 10 minutes.
PCHiggin
3,886
Ryderwood, United States
I’d change the rear sprocket,I’ve done it on a few bikes. Changing from an 18 or 19T to a 22T makes a huge difference and you can keep the cool
looking 52T front sprocket.
fattyre
Oct 22, 2014
957
Chicagoland
This will provide you info on ratios (for 1/2 inch pitch) and how much of a difference they will/can make. It's all about gear inches. That is how much the wheel will rotate with every revolution of the crank.
http://www.bikecalc.com/gear_inches
Reactions: phantom
phantom
1,306
GA
Currently has a 21 on the rear and 52 on front. I am going to a 48 Clover leaf. I'll get the gear I'm wanting and as a bonus I get the preferred look that I like better.
Sep 2, 2012
11,256
Central Arizona
The Schwinn clover ring is a 46 tooth.
bikemonkey
1,323
67
Yeah - if you are already running a 21T cog then the front end is where you need to go.
phantom
1,306
GA
I know there are a few 46T clover leaf rings on the bay...If anyone here has a real nice one they want to get rid of reasonably, send me a message. Thanks
