Goldenrod
Soak it in a 50/50 solution of acetone and ATF - automatic transmission fluid. Work each joint by hand and keep soaking till the rust is gone. DO NOT use a hammer on it. Even a rubber hammer can bend something. The hammer will not get rid of the rust. Also, 1:9 solution of molasses to water will work but it might take longer - smells better though. Don't use gasoline for anything but fueling your car. A spark from you hammer could have started a fire.
Wash well after handling acetone.
