Oxalic Acid Bathing
Discussion in 'Project Rides' started by pedalpower17, Oct 25, 2017.
  1. #1 Posted Oct 25, 2017
    Oct 20, 2010
    63
    23
    Does anyone have experience with this treatment on small non-painted and non-chrome parts, such as fender braces, spokes, brake arms, nuts & bolts?
    What if anything, should be done to these parts after treatment?
  2. #2 Posted Oct 25, 2017
    Nov 30, 2014
    685
    1,889
    Littleton, CO
    I wash them off immediately after removal with clean water and a rag. There is a white film that forms on the parts. It's comes off easy.
    Chad
    pedalpower17 likes this.
  3. #3 Posted Oct 25, 2017
    Jul 14, 2009
    13,491
    11,679
    Evans, GA
    Wash them with soap and water. After thoroughly drying I use a light coat of Johnson's Paste Wax to protect the part. I do the same for painted parts. I have been told that if you get too strong of a solution it may cause some cad parts to turn black so you may want to experiment on a similar part first. V/r Shawn
  4. #4 Posted Nov 1, 2017
    May 5, 2014
    199
    95
    Santa Cruz,CA.
    I got some of the acid on the way from Amazon, what is the best mix ratio for painted/rusty parts?
  5. #5 Posted Nov 4, 2017
    Feb 16, 2008
    10,160
    3,781
    Portland, OR 97206
    #5 Boris, Nov 4, 2017
  6. #6 Posted Nov 5, 2017
    Nov 2, 2008
    10,416
    4,989
    crown point<indiana
    I use one tablespoon per gallon.
  7. #7 Posted Jan 20, 2018 at 6:36 AM
    Oct 23, 2016
    976
    484
    Tucson
    I’m going to try this on my next resurrection project. I can’t believe the results guys have with this method.
  8. #8 Posted Jan 20, 2018 at 6:49 AM
    Jun 3, 2013
    2,704
    4,329
    Tuxedo Park, United States
    I've had excellent results on frames, where it brought the paint back to life. With spokes & fender braces, I've not had any worthwhile results.
  9. #9 Posted Jan 20, 2018 at 10:26 AM
    Jun 29, 2012
    2,496
    134
    Alameda, California
    Use two tablespoons per one gallon of hot water.
    After rust removal, soak in baking soda solution. This neutralizes the acid, especially under hard to reach parts....
    Boris likes this.
