Pierce Arrow Antique Racing Bicycle
stingrayjoe
2,468
Central NJ
I bought this today from a local antique dealer. Looks like an old repaint. Top bar and down tube have dents. Top plate on right fork is stamped Pierce. Wheels match and hubs have all old hardware. No makers marks on the hubs. Rear wheel spins pretty true, front has wobble in rim. Rear cog is welded fast to lock ring. Frame is 21". Seat is signed on sides but is not legible. One hedbadge screw is broken off.
What time frame do you think it is from?
Thank you.
gkeep
Jun 11, 2014
763
Alameda, CA
Does the the headbadge have Buffalo or Angola as the city?
Reactions: tripple3
Archie Sturmer
1,287
Los Angeles, CA, USA
No coaster brake, and the front end was bent; wonder how that may have happened.
Maybe a "Frank Amateur Racer".
Reactions: stingrayjoe
GiovanniLiCalsi
4,024
Alameda, California
Reactions: piercer_99 and dnc1
piercer_99
2,224
59
Sanger, TX
shame about the top and down tube being destroyed.
The headbadge is Angola, I would agree that it looks like an amateur racer, similar to mine.
1103892
1103891
ps, they are Pierce Cycles, no arrow in the name.
1103893
stoney
3,552
65
Fuquay Varina, NC, United States
Yes, a few issues but still a cool looking bike Joe.
Thank you.
Yes a few issues but still a cool looking bike Joe. I like it.
olderthandirt
Jun 15, 2012
506
pilot mt n.c.
heck all it needs is a little bondo use a little extra hardener then just smooth it out and its good as new and strong too ! most new cars have it in them from the factory ! another great product is alumi/lead its a powdered metal based product it uses fiberglass hardener to activate ,you can drill and tap the stuff the white based product can be used to repair bridge work, it still will pop loose when crunching ice <darn it>have not found anything to hold up to ice ! and yes we have tried dental porcelain several times .the product used to spot repair cannot be heated up to a high enough temperature to get it hard enough to bond and cure enough to handle ice !< have tried several blends ect > anyone else had any good luck ?
GiovanniLiCalsi
4,024
Alameda, California
1103892
1103891
1103893
Use this tool and just touch up the area.
