jd56
If he'd respond then, that would be acceptable.Honestly, take a step back, look at the state of the rims you've got. It looks like the axle nut that poked through there still made it to you with some luck. Is it worth blasting the guy over a hole in a box?
The perpetrators that are never willing to take blame or held truly accountable are the shipping companies in these situations... especially for lost and damaged packages.
No need to blast him here.
But, I did have to trace the tip of the stud threads. Not a bug deal but, so easily could have been avoided.
Also cause the tire sidewalls weren't protected the gum walls were marred up. But still nice tires
And one of the shrader valves must be damaged because it won't engage the air chuck.
Shame I'd have to unglued the tires to replace the stem.
Front tire inflated nicely.
The process of packing is to ensure no protruding parts or the ability to allow holes to picture the carton.
Holes created allow the loose parts if any to fall out.
And yes, the courier is partly to blame for the damage.
