Marshall Waha
Hi Cabe Memembers!
Happy Holidays I hope you are all well. I have some questions:
1.) Has anyone ever seen a Schwinn Rim Stamped Schwinn Tubular with no Valve hole?
2.) Could a valve hole be drilled in a rim that didn't have a valve hole to begin with or would that compromise structural integrity?
Only reason I am asking is I came across these two ebay listings:
20” Tubular S-2 28h Chrome Knurled RIM Stingray Double Stamped No Valve Hole
Schwinn Stingray S–2 Side Stamped 20" 28 spoke No Valve Hole
I found these to be a bit odd, because (and this is a rhetorical question but please correct me if I am wrong here), don't all stamped or nonstamped Schwinn Stamped Tubular Rims have a valve hole? I have seen non-valve hole rims on an old Sears bike that a friend gave me but no longer have. But not on a Schwinn rim stamped Schwinn Tubular rim before. The real question is: Is the seller lying in the listings above or are they telling the truth? Because I've bought from this seller before, for example I purchased Shimano D-Type coaster brake 28h hub the seller had it listed as a 36h but in the description he called it 28h, I then had to ask this seller was this 28 holes or 36 holes they said 28h. I then told them they needed to revise their listing (eventually it did get revised by ether the seller or eBay that will forever remain a mystery.) because you can't lie and call something one thing and contradict it with the truth in an item's description, that doesn't add up or make sense. Hopefully most of you agree. Anyways I just found this strange and had to ask. For the most part otherwise the seller seems to be pretty truthful and trust worthy, but I find this to be odd. Also I may or may not be posting in the Wanted Section for a S-2 stamped Schwinn tubular rim, I already have two S-7's for my 1965 Schwinn Deluxe Stingray simply because I really don't want to deal with two different wheel sizes and would rather have two of the same wheel sizes as well as two different spoke sizes even if that's not what came from the factory, but I may change my mind so I am going to wait and see. Anyways happy Holidays everyone! Thanks Marshall D.WahlstromHelgren
