I was lucky enough tobe the new owner of this bicycle - thanks again Mark for letting me have it.
And luckily the original Lenox sales catalog (with that modell) was available on Ebay at the same time (mentioned by Blue Streak above) - being able to secure that one as well makes me even more happy.
I especially like the crank mechanism- an ingenious arrangment, where the cranks are held together by a long screw and, due the slanted contact area, are pushed outside, "expanding in diameter " so to say, and hence: clamp the surrounding, hardened bushing which bears the tapered surface, for the ball bearing. The cups containing the balls are screwed into the bottom bracket.
Once the play of the crank bearing is set, the cups are clamped tight by two set screws compressing the bottom bracket.
All bearings of the machine are in decent condition and run really smooth.
I'm always stunned how many US bikes have surived over time, even with their original (or period correct) tires still mounted - this is rellay amazing to see (and amazing to imagine how long these machines have stayed unused, stahsed away in qa hidden corner.
In Germany you rarely find such old bikes with their "factory pneumatics" still mounted.
Despite being complete, the original wheel set and saddle are far beyond ridebale condition , and I would not even attemp to "fix" them, but rather keep these itmes as they are for display.
Since I also want to ride the bike ( for a certain time), I opted for setting up a repro wheel set:
The rims are from Ghisallo (Italy) wood rims with a carbon fibre support ring , hidden on the rim bed.
I stained them to "Hickory Yellow" and laced it with nickeled, double swaged spokes NOS and soldered the crossings.
The rear received a ND Model A, for the front I copied the original Lenox hub on my lathe and did "chemical nickeling", which can slo be done at home, without galvanic gadgets.
I can absolutley recommend these rims, I have two clincher sets of them, on the Lenox is a large 28" set (635mm) my Pierce has a small 28" set (622mm).
You can order your custom hole-count, bed profiles for tubular or clinchers and several inner rim shapes (rectangular, beveled balooners etc.) in different widths...
They even carry the long nipples+washers, nickeled or plain brass surface.
The saddle mounted on the picture is also old, but not as valueable.
The chain which came with the bike looked great, but was lenghtend too much for riding
So thanks again to the Cabe I found a chain here on DOND.
It was a bit short so I manufactured the missing blocks+ links (four black ones on the bottom in picture)
The rear sprocket is self made as well.
All bearings were inspected, cleaned, oiled/greased. The entire machine was gently cleaned and waxed, that was it - no chemicals, boiled line seed or similar.
At the moment I'm riding this bike quite often, but in a few weeks/months it will go back on display, receiving its original tires and saddle back.
I think this is a nice method of enjoing your machine while actually riding it, without taking a risk to destroy brittle, original items.
I can enjoy an old machine by looking at it, enjyoing the details etc. , but for me it is even more rewarding to also ride and feel the bike.
