I’m not a welding expert but I’m pretty sure that’s not true. Electro-forging and arc welding are not the same. They share the use of electricity to produce heat but there are many differences. Arc welding requires setting up an “arc” and that is only possible if there is space between the two metals connected to the different sides of the electrical power supply. It’s ionized gas (plasma) that makes the heat in arc welding.
In resistance welding like the CWC “Hart” method or the Schwinn “electro-forging” method it is the current passing through the resistance at the interface between the two metals connected to the different sides of the electrical power supply. Very high current is passed through the interface resistance and heat is created. The two parts are smashed together during this process and there is no space to creat an “arc”.
Here is a site where you can see a comparison of the methods.
Comparison Site
