All about the Whizzer h motor! Please post all info!
So here is what I'm going to use as a spare magneto. I don't know if it will work but I'm going to give it a try when I get it running. It's an original E bracket with a Tecumseh coil. It's not pretty but I used a file to remove .1" and .025" from the center of the coil where the center of the E bracket attaches to the coil because it was .4" by .4" square and I needed it to be be .425" by .5" and I haven't decided yet how I'm going to attach it yet probably something that I can remove easily so I can change it if it goes bad. It even comes with a spark plugs wire that is long enough to reach the plug without any modifications I think. I didn't install it on the motor but I think it will reach but for the $ I couldn't go wrong with trying it out. I just couldn't see myself spending over $100 for one to put on a bike that is never going to be a show bike or all original. I just want to ride it! Think it will work?
What was wrong with the old coil? And are you using points?
Nothing is wrong with the old coil or the original spark plug I just cleaned it up. I'm using an ignition module. I turned the motor over with a drill and have excellent blue spark not even spinning it fast. I just wanted to see if I could get a different coil to work so I have a spare. I don't mind paying for those manuals but I don't think that it's right the price some people are selling them for when all they are doing is copying them!
I just bought a Whizzer H. I wasn't able to get it going. I've ordered a electronic ignition module. My question was this.
In order to have the engine properly timed. Is there markings (or the hole might be a good reference point) on the flywheel that need to be at a particular position (something o'clock) in order to get it to fire properly. Any help would be appreciated. Thanks.
Here this might help
1226398
1226399
1226400
1226401
