Bendix Sturmey Archer Shimano 24 and 28 tooth rear sprockets
$25.00
Paypal or a good check
Ash Grove MO
Mike just made a 1" pitch skip tooth version of these 3-tab cogs. He is sending it to me for a real time field test. He wants to make sure the Skip Tooth version is worth making as long as it mounts and runs smoothly without problems. I will come back to post it here with results after a few solid rides...pete.
Now we're talking! 🤓
The Ichi ones are hard to find right now...
I have been buying these then dremmel cutting off every other tooth. Hard metal, offset for chain line adjustment, and inexpensive. Quiet as well compared to the sharp-edged Ichi with flats instead of curves interacting with the rollers & links. I had to dremel the sharp edges down on that Ichi cog to shut it up, it was really loud when new.
These thinner 1/8", or 3mm cogs when run with wide skip tooth chains will set on either the inside or outside of the wider chain roller, depending on the bikes' chain~line. I do not think it affects the chains' wear, although you can flip the chain every year to distribute wear more evenly.
