I want to try and rebuild the CWC klunker as a 14-speed hybrid for this year's Off Road Build Off on ratrodbikes.com, but I've got one big issue that I'm not sure how to solve. I've only worked with derailleurs once before, and that was with a postwar Schwinn, which has "normal" dropouts, which meant I could just use a regular Shimano dropout-attached derailleur from one of my donor bikes.
On this 1936 CWC though, I not only have dropout slots that face the wrong way, but there's also a piece of metal under the dropouts that bends out and away from the axle.
My original plan was to use one of these derailleurs that bolts onto a little hanger that sits below the dropout. I was just going to drill and tap one of the kickstand/fender mount holes to tit the dropout, and then maybe cut off part of the kickstand stopper.
But then I noticed this weird protrusion on the derailleur, and saw how it actually mounted to the bike it came from. I don't think this derailleur will work for this bike like I thought, as that might take a little too much fabrication for me to do on my own.
So, after dragging my feet on this for nearly a month, I decided to see if I could even slide a regular dropout-mounted derailleur on this bike. It turns out, I can, and I might even be able to clear that kickstand stopper too.
Then again, that kickstand stopper might be in the way of the cables...
The arm of this derailleur moves away on this frame, unlike the more modern Shimano that came with a 7-speed freewheel, which sits flat against the dropout.
I mocked up this other derailleur, which might work, but I'm still unsure about it.
There are a couple concerns I have about using these older derailleurs on this klunker:
1. I don't know if they'll actually clear the frame just fine, or if I need to either bend or cut off the one piece that might be in the way in order for them to work.
2. I'm pretty sure these derailleurs were for 5-speed wheels. Would they still work on a 7-speed with some adjustments, or is that just not feasible?
I could use some help figuring out how to work around these issues. I'd like to avoid welding or brazing some adapter on this frame, as I have neither the tools nor expertise to do that. Plus, I'd really like to use the parts I have, instead of going out and buying a new part just to solve this problem. If I could get some advice on how to turn this CWC into a 14-speed using what I have, I'd appreciate it. Honestly, even if it turns out that I'm better off keeping this bike as a single-speed bomber, then that helps too.
