Tips for Mounting Rubenas on G&J clincher rims?
gkeep
I know many have been using the Rubena bead less tires on G&J clincher rims. Are there any tips or tricks to ease the process of getting them seated in the rim?
Thanks for any and all advice.
C M Gerlach
I have had these off and on a few times....used cheap tubes the first time and regretted it.
last time I had the tires pretty warm, and slightly inflated the tube, just enough to take shape,then go around the rim rocking the tire side to side and you will feel it "snap" into the groove. I add just a little more air and repeat.
cyclingday
Start with the inner tube slightly inflated, and installed in the tire.
Then, put one side on first, then work your way around snapping the other side in.
It’ll get easier as you progress.
Once you have both sides seated, rock the tire from side to side to get the bead to lock into the hooked rim.
gkeep
Are these the brown color? They look more clay colored in your picture. Very nice!
They are a very light brown, mocha, taupe? I have them on the rims but not yet back on the bike. Busy week and tryingnto find some hours to do a little cleaning/lube/maintenance on the bike with the rims off.
I ordered these from Adam at Peco Bikes in Slovakia. Shipping for three sets was $55 and they arrived in one week. He was a great guy to deal with. He of course cant get any cream, just black, red and brown at this time. I notched the corner of the bead to fit around the valve stem so the beads could meet like the old catalog illustrations. When they pop into the rims they can really 'pop'.
Dra
Did you have to drill the rim for the Schrader valve stem? The brown is starting to grow on me. Someone will eventually have the cream ones hopefully in my life time ride on
cyclingday
Yeah, as a helpful tip, for the guys using these tires, I use a paper hole punch to notch both sides of the opposite edge of the bead, where the valve stem goes.
I put that notch below the area where the PSI information is on the sidewall of the tire.
gkeep
The valve hole was just a hair undersized for a Schrader, a few strokes with a rat tail file and then I cleaned up the edges with some emery cloth around a dowel. Glad I'm not having to deal with the presta valve adapters anymore.
