Collegiate headset question…
Also have a close look at the VSF bearing that goes in the lower cup. It is an odd one that looks upside down when it is right side up.
Use a postwar Schwinn crown race (or some other one that is intended for a VSF bearing) on the fork if you can.
Some pics,
GT post #13 deluxe headset, left is D & E, right is F, G, H
1603850
And bloo post 21, pic of smushed face vsf proper orientation
1603852
1603853
1603854
So I was trying to use a 2 speed kickback wheel set in this collegiate on S6 hoops. Looks like I need a different chain and possibly front sprocket?
The Collegiates were derailleur geared bikes that used a 3/32" chain. After the 1968 models Schwinn stamped knurling on the chain rings around the crank hole to indicate the ring was for the 3/32" chains. Did you resize that chain?
Ahhh, I was wondering what that was for! Looks like I got some work to do.
Yeah, i had the knurled sprocket and that two-speed kickback with a 3/32 chain.
what’s the problem? 🤣
need to dig through my parts bin and see if I have a knon-knurled sprocket and most likely need to buy a new/old chain.
thanks!
